How to get full refresh to work in MVC razor
I have tried to get full refresh to work with MVC and razor the way episerver suggests but so far no luck. I will write below what I did and also what workaround I used to get it to work.
I have a boolean property on one of my blocks that adds a border. What I wanted to achieve was to make a preview page for the block that updated the visuals of the block when the value of that Boolean changed. This required a page refresh then the property changed. I tried following this example in the episerver sdk http://sdkbeta.episerver.com/SDK-html-Container/?path=/SdkDocuments/CMS/7/Knowledge%20Base/Developer%20Guide/Content/Pages%20and%20Blocks/How%20To/Edit%20hints%20in%20MVC.htm&vppRoot=/SdkDocuments//CMS/7/Knowledge%20Base/Developer%20Guide/ .
This is what I did.
In the controller I added AddFullRefreshFor for the border Boolean.
var editingHints = ViewData.GetEditHints<ViewModel,EpiBlock>();
editingHints.AddFullRefreshFor(p=>p.Border);
In the view I added the full refresh method and the property.
@Html.FullRefreshPropertiesMetaData()
Border: @Html.PropertyFor(m=>m.EpiData.Border)
This did not work.
It looks like there is a bug in the FullRefreshPropertiesMetaData method.
public static MvcHtmlString FullRefreshPropertiesMetaData<TModel>(this HtmlHelper<TModel> helper)
      if (RequestContextExtension.GetContextMode(helper.ViewContext.RequestContext) == ContextMode.Edit)
        IList<EditHint> list = helper.ViewData[ViewDataKeys.FullRefreshProperties] as IList<EditHint>;
        if (list != null && list.Count > 0)
          return PropertyExtensions.FullRefreshPropertiesMetaData((HtmlHelper) helper, Enumerable.ToArray<string>(Enumerable.Select<EditHint, string>((IEnumerable<EditHint>) list, (Func<EditHint, string>) (e => e.ContentDataPropertyName))));
      return MvcHtmlString.Empty;
The helper.viewdata returns a list of strings that can't be cast to a IList<EditHint> and thus it will always be null.
SOLUTION
The solution that I did was to write my own extension method that solves this.
public static MvcHtmlString FullRefreshPropertiesMetaDataThatActuallyWorks<TViewModel>(this HtmlHelper<TViewModel> me)
             var refreshProperties = me.ViewData[ViewDataKeys.FullRefreshProperties] as IEnumerable<string>;
             if(refreshProperties != null)
                 return me.FullRefreshPropertiesMetaData(refreshProperties.ToArray());
    And call this method in the view instead.
#65719
Feb 06, 2013 15:45
That sure looks like a bug. I'll add it to our bug tracker.
Thanks for reporting this, and also for providing a work around.
Update:
Bug registered as: #95628: Not possible to add full refresh using the FullRefreshPropertiesMetaData extension method
Regards
Per Gunsarfs
EPiServer Development Team
#65724
Edited, Feb 06, 2013 16:35
