Problem with remapping DDS
I have a Comment class where i changed both a property name and type and now i get this error when calling GetStore:
[StoreInconsistencyException: The Type 'EPiServer7RnD.Business.PageComment' needs to be remapped in the Dynamic Data Store, see the Errors collection for more information.
Remapping can be done by applying the EPiServer.Data.Dynamic.EPiServerDataStoreAttribute attribute to the type,
setting its AutomaticallyRemapStore property to true and ensuring the <episerver.dataStore><dataStore> autoRemapStores attribute in web.config is set to true (or is not defined).
Alternatively call the Upgrade-EPiRemapDDSTypes cmdlet from Powershell.]
I have tryed this but still the same error:
 [EPiServerDataStore(AutomaticallyCreateStore = true)]
    public class PageComment : IDynamicData
        public Identity Id { get; set; }
        public DateTime Time { get; set; }
        [EPiServerDataPropertyRename(OldName = "PageID")] This used to be an int called PageID
        public ContentReference PageRef { get; set; }
        public string UserName { get; set; }
        public string Text { get; set; }
#78770
Dec 03, 2013 13:14
Have you tried the AutomaticallyRemapStore=true.  That should do the trick for you.
#78802
Dec 03, 2013 18:04
We have a known issue when removing types, where a DDS store earlier had a property of the removed type. Renaming of a type might give the same problem. Bug number 108992.
#78867
Dec 04, 2013 13:53
