404 Handler not supporting more than one language?
I recently downloaded the 404 Handler:
https://www.coderesort.com/p/epicode/wiki/404Handler
It is working ok so far, but the only issue I'm having is that I don't know how to use for example the Swedish xml-file where all the text that is visible on the 404 page is stored. I thought that if you are visiting the Swedish site and when you are redirected to the 404 page it will automatically use the xml-file for that language. But apparently that doesn't happen. Have I misunderstood something here? Do I have to do something else to make this work?
Thank you!
#79348
Dec 13, 2013 15:31
Out of the box, it will not automatically detect which language you are using. You could extend the functionallity yourself by either checking on the current browser language, or by checking on the language segment on the current url.
#79374
Dec 16, 2013 9:28
Ok. Thank you! I'll try that.
#79378
Dec 16, 2013 10:22
