Restrict Blocks in ContentArea
I'm having a issue restricting what kind of Block to be inserted in a ContentArea. What I want is that the SliderBlock's ContentArea property can only have insertion of a SlideItemBlock.
My block classes:
[ContentType(...)]
public class SlideItemBlock : BlockData
	[Required]
	Display(Name = "Image")]
	public virtual string Image { get; set;}
[ContentType(...)]
public class SliderBlock : BlockData
	[Required]
	[Display(Name = "Slides")]
	public virtual ContentArea Slides { get; set; }
	//Should only accept insertion of SlideItemBlock
Or is this the wrong way to achive what I'm trying to restrict for the editor to not drag and drop wrong block types?
As of now, I can create a SliderBlock and insert a SlideItemBlocks in it. If I then insert the created SliderBlock in a new SliderBlock I get a forever and ever loop and It breaks the site. This is what I'm trying to control.
#77678
Nov 22, 2013 14:30
What you could very easily do is to implement IValidator class that will be triggered when a page/block is saved.
See the following example, but you might use any condition you like:
    public class CarouselContentValidator : IValidate<StartPage>
        IEnumerable<ValidationError> IValidate<StartPage>.Validate(StartPage instance)
            if (instance.CarouselContent.AnyBlocks())
                if (instance.CarouselContent.Contents.Any(
                    c => !c.GetOriginalType().IsAssignableFrom(typeof(TextOverImageBlock))))
                    var validationError = new ValidationError
                        ErrorMessage = LocalizationService.Current.GetString("/validation/carouselblocks"),
                        PropertyName = "CarouselContent"
                    return new[] { validationError };
            return Enumerable.Empty<ValidationError>();
#77681
Nov 22, 2013 15:02
I get an error for GetOriginalType(). It says EPiServer.Core.IContent does not contain a definition for this. How can I fix this?
#77682
Nov 22, 2013 15:32
Hmm, that's strange, for me it works like charm, let me think about it...
#77683
Nov 22, 2013 15:37
You can also implement ValidationAttribute (http://msdn.microsoft.com/en-us/library/system.componentmodel.dataannotations.validationattribute(v=vs.110).aspx) to handle the validation directly in the attribute whereever it's used. We will have a built in attribute to handle this in the 7.5 release.
#77688
Nov 22, 2013 17:44
I found this on nuget and it solves all of my problem with ContentAreas restrictions.
http://www.nuget.org/packages/OpenWaves.EPiServer.ExtendedContentAreaEditor/
#77863
Edited, Nov 27, 2013 12:37
"I get an error for GetOriginalType(). It says EPiServer.Core.IContent does not contain a definition for this. How can I fix this?"
I recently had the same problem after updating Episerver from the oldest possible version 7 to the latest.  The solution was to add a "using EpiServer;" reference to the top of the document, as the method is an extension defined in EPiServer.RuntimeModelExtensions. I have no idea why the reference wasn't needed on the old codebase, but adding it after the update made it work again.
#79343
Dec 13, 2013 13:51
Ripped From the AvailablePageTypes type attribute:
[AttributeUsage(AttributeTargets.Property)]
public class AvailableContentTypesAttribute : ValidationAttribute
    public System.Type[] Include
        get;
        set;
    public System.Type[] Exclude
        get;
        set;
    public override bool IsValid(object value)
        if ((value != null) && !(value is ContentArea))
            throw new ValidationException("AvailableContentTypesAttribute is intended only for use with ContentArea properties");
        var contentArea = value as ContentArea;
        var notAllowedcontentNames = new List<string>();
        if (contentArea != null)
            if (Include != null)
                var notAllowedContent = contentArea.Contents.Where(x => !ContainsType(Include, x.GetType()));
                if (notAllowedContent.Any())
                    notAllowedcontentNames.AddRange(notAllowedContent.Select(x => string.Format("{0} ({1})", x.Name, x.ContentLink.ID)));
            if (Exclude != null)
                var notAllowedContent = contentArea.Contents.Where(x => ContainsType(Exclude, x.GetType()));
        if (notAllowedcontentNames.Any())
            ErrorMessage = "contains invalid content items :";
            foreach (var notAllowedcontentName in notAllowedcontentNames)
                ErrorMessage += " " + notAllowedcontentName + ",";
            ErrorMessage = ErrorMessage.TrimEnd(',');
            return false;
        return true;
    private bool ContainsType(Type[] include, Type type)
        return include.Any(inc => inc.IsAssignableFrom(type));
    protected override System.ComponentModel.DataAnnotations.ValidationResult IsValid(object value, System.ComponentModel.DataAnnotations.ValidationContext validationContext)
        var result = base.IsValid(value, validationContext);
        if (result != null && !string.IsNullOrEmpty(result.ErrorMessage))
            result.ErrorMessage = string.Format("{0} {1}", validationContext.DisplayName, ErrorMessage);
        return result;
Usage:
Explicit inclusion:
[AvailableContentTypes(Include = new[] { typeof(SomeBlockType), typeof(SomePageType) })]
public virtual ContentArea ContentAreaProperty { get; set; }
Explicit exclusion:
[AvailableContentTypes(Exclude = new[] { typeof(NoAllowedBlockType), typeof(NotAllowedPageType) })]
Prevents the ContentArea container from saving until only the correct types are included.
regards,
Danny
#79808
Edited, Jan 08, 2014 9:19
Thanks @Alabin
It helped me too.
#155497
Sep 19, 2016 14:24
