Render Usercontrol Blocks from ContentArea?
Im new to EPiServer , so sorry If this is a dumb question.
In the current project Im working at I have created a Site Settings pagetype where I store all of my global fields for my site. For example I have put my footer contents in there. My idea is that my footer is build with different blocks that I insert in a ContentArea field.
How can I render the blocks in that ContentArea field so each block use it's created usercontrol?
As of now, I have to render the contents from the ContentArea in codebehind in my footer usercontrol.
Best Regards / The rookie Daniel
#77445
Nov 19, 2013 15:10
In your masterpage you add a <EPiServer:Property control. You set PropertyName to the name of your contentarea property,then you set the PageLink to your settings page type and your done.
#77455
Nov 19, 2013 21:31
