NuGet Package Squishit.Less breaks EPi 7
Does anyone had the problem when you install Squishit.Less from nuget in your solution and after that breaks the site? Every page is white blank. When I remove the package it works again. Hmm....
#77178
Nov 12, 2013 15:00
Just installed it without any problems on an existing site. Are you getting 404 or 200 responses back from the server?
Frederik
#77180
Nov 12, 2013 15:21
I tried a fresh install of EPi 7 using the Visual Studio extension tonight. Everything works great until I run "install-package squishit.less" in NuGet. The following files are added to the project:
  • SquishIt (≥ 0.9.3)
  • YUICompressor.NET (≥ 2.0.0.0)
  • AjaxMin (≥ 4.48.4489.28432)
  • dotless (≥ 1.3.1.0)
  • WebActivator (≥ 1.4)
  • Microsoft.Web.Infrastructure (≥ 1.0.0.0)
In web.config this is added:
<configuration>
<configSections>
<section name="dotless" type="dotless.Core.configuration.DotlessConfigurationSectionHandler, dotless.Core" />
</configSections>
<system.webServer>
<handlers>
<add name="dotless" path="*.less" verb="GET" type="dotless.Core.LessCssHttpHandler,dotless.Core" resourceType="File" preCondition="" />
</handlers>
</system.webServers>
<dotless minifyCss="false" cache="true" web="false" />
</configuration>
I have set up my site host to be http://epiforms/ on the IIS. When I browse to the adress I get a blank white page and the response is 500 Internal Server Error (checked with Google Chrome Development toolkit).
Any idea?
#77205
Edited, Nov 12, 2013 21:28
If I turn on logging I get the following:
2013-11-12 21:38:56,533 [94] ERROR SearchSettings: Update batch could not be sent to service uri 'http://epiforms/IndexingService/IndexingService.svc/update/?accesskey=local'. Message: 'The remote server returned an error: (500) Internal Server Error.   at System.Net.HttpWebRequest.GetResponse()
   at EPiServer.Search.RequestHandler.MakeHttpRequest(String url, NamedIndexingServiceElement namedIndexingServiceElement, String method, Stream postData, Action`1 responseHandler)
   at EPiServer.Search.RequestHandler.SendRequest(SyndicationFeed feed, String namedIndexingService, Collection`1 ids)'
2013-11-12 21:38:56,534 [94] ERROR SearchSettings: Send batch for named index 'serviceName' failed. Items are left in queue.
#77206
Nov 12, 2013 21:40
