What is your controller inheriting from? Are you inheriting from EPiServer.Web.Mvc.PageController<SomePage>?
Basically, your controller should look something like this:
public class TextPageController : PageController<TextPage>
public ActionResult Index(TextPage currentPage)
var viewModel = new TextPageViewModel(currentPage);
AutoMapper.Mapper.Map(currentPage, viewModel);
return View(viewModel);
Your view should be in Views\TextPage\Index.cshtml and should declare the correct Model:
@using EPiServer.Web.Mvc.Html
@model Xx.Web.Views.TextPage.TextPageViewModel
Hi Johan,
First of all, your page controller must inherit from PageController<T>, like this:
public class SomePageController : PageController<SomePage>
Since the action expects a SomePage object, I can't return a SomePageModel object
Actually, you can return any action result you want.
public MvcHtmlString Index(SomePage currentPage)
return new MvcHtmlString("This works, too!");
Index(SomePage currentPage) part is called model binding. You can find more info about model binding on the following link http://msdn.microsoft.com/en-us/magazine/hh781022.aspx
EPiServer has created their own model binder, and you need to follow their name convention in order to make it work. So you can't have SomePage myPage, you must use SomePage currentPage for pages, and SomePage currentBlock for blocks.
Let's say that you have defined your page type like this
[ContentType(GUID = "2F5BE1AA-2E32-43C7-8520-39A9C91DB069")]
public class SomePage : PageData
public virtual string SomeProperty { get; set; }
In case you wan't to work with SomePage directly, you would have something like this:
Controller
public ActionResult Index(SomePage currentPage)
return View(currentPage);
View
@model SomePage
Layout = null;
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="width=device-width" />
<title>Index</title>
</head>
<body>
@Html.RenderEPiServerQuickNavigator()
@Html.FullRefreshPropertiesMetaData()
<div>
<p @Html.EditAttributes(x => x.SomeProperty)>@Html.DisplayFor(x => x.SomeProperty)</p>
</div>
</body>
</html>
In case you want to have a ViewModel that has a reference to CurrentPage, you would have something like this:
ViewModel
public class SomePageViewModel
public SomePage CurrentPage { get; set; }
// other properties
Controller
var viewModel = new SomePageViewModel { CurrentPage = currentPage };
View
@model SomePageViewModel
Layout = null;
<!DOCTYPE html>
<html>
<head>
</head>
<body>
<div>
<p @Html.EditAttributes(x => x.CurrentPage.SomeProperty)>@Html.DisplayFor(x => x.CurrentPage.SomeProperty)</p>
</div>
</body>
</html>
Or in case you don't want your view model to have a reference to CurrentPage, you could have something like this as well:
ViewModel
public string SomeProperty { get; set; }
// other properties
Controller
var viewModel = new SomePageViewModel { SomeProperty = currentPage.SomeProperty };
View
Layout = null;
<!DOCTYPE html>
<html>
<head>
</head>
<body>
<div>
</div>
</body>
</html>
Make sense?
Hey Dejan, all that makes perfect sense and was the way I thought it would work.
I found my problem. My view was still using the SomePage object as a model and not the new SomePageModel object.
Thanks for a good and thorough response.
How do I work with view models?
This doesn't work,
var model = new SomePageModel
PageData = currentPage
return View(model);
Since the action expects a SomePage object, I can't return a SomePageModel object, which is reasonable. But as I understand it, to get the currentPage data object I need to have (SomePage currentPage).
So how do I do this right?
