Get the available languages of a block
Hello,
I have a block but how can I enumerate and get this block in the different available languages?
REgards,
Benjamin
#77498
Nov 20, 2013 11:56
Use the content repository and it's method GetLanguageBranches:
IEnumerable<T> GetLanguageBranches<T>(ContentReference contentLink) where T : IContentData;
#77506
Nov 20, 2013 12:53
This work for pages but how can I do that for a block? Because I don't know how to create a ContentReference from a block who inherit from BlockData?
#77511
Nov 20, 2013 13:37
Either you have a block as a property on a parent model, for instance a page. Then you should check the page. If it's a shared block then you should have a reference to that block (either through a property or as part of a property, for instance a content area) and you can then use that reference.
#77518
Nov 20, 2013 14:28
Just to clarify, if it is a shared block instance you can cast the instance to IContent.
#77519
Nov 20, 2013 14:30
