Custom Visitor Group enum dropdown not populating
Hello everyone
I'm building a custom visitor group but the match criteria drop down doesn't populate from an enum. I'm coding as the following
[EPiServerDataStore(AutomaticallyRemapStore=true)]
    public class SearchParameterModel : CriterionModelBase
        [Required, DojoWidget(SelectionFactoryType = typeof(EnumSelectionFactory))]
        public SearchValueCondition Condition { get; set; }
        [Required]
        public string Value { get; set; }
        public override ICriterionModel Copy()
            return base.ShallowCopy();
    public enum SearchValueCondition
        Match,
        StartsWith
but the dojowidget doesn't pick up the enum and i can't see why and I can't see how to debug further.
If a create a custom selection factory like this
    public class CustomSelectionFactory : ISelectionFactory
        IEnumerable<SelectListItem> ISelectionFactory.GetSelectListItems(Type property)
            return Enum.GetNames(property).Select(n => new SelectListItem { Text = n, Value = n });
Then it will populate (horray) but when I go in to edit a saved criteria then the item the user selected is lost and needs to be readded (booooo). If I could get either one working then I'd be happy but at the moment neither works fully
As anyone got any advice/tips . As always all help sis gratefully received
Many Thanks.
#77864
Nov 27, 2013 13:24
Hi Tim,
First thing I can say with your version 1 is: You will get missing text (because in EnumSelectionFactory will use LocalizationService to get text for each value)
2nd version should cast value to int like this:
return new SelectListItem
                    Text = n,
                    Value = ((int)n).ToString()
Hope that help!
Ha Bui
#77885
Nov 28, 2013 7:55
Thanks you for that. Unfortunately the code won't compile so I changed to
                Text = n,
                Value = Convert.ToInt32(n).ToString()
But this causes the visitor group to crash with 'input string is not in correct format'
With the first version - the localisation service should pick up from an aml file in language. But i have one with the below format
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<languages>
    <language name="en" id="en">
        <shell>
            <cms>
                <visitorgroups>
                    <criteria>
                        <search>
                            <key>Term:</key>
                        </search>
                    </criteria>
                </visitorgroups>
            </cms>
        </shell>
		<enums>
			<criteriapack>
				<searchcriterion>
					<searchvaluecondition>
						    <match>Match</match>
                <startswith>Starts with</startswith>
          </searchvaluecondition>
				</searchcriterion>
			</criteriapack>
		</enums>
  </language>
</languages>
Is that wrong?
Any other thoughts would be really appreciated
#77911
Edited, Nov 28, 2013 11:13
Actually i don;t need this to be perfect so I have just associated it with the actual instance of the enum. Works fine but won't win prizes
    public class SearchValueSelectionFactory : ISelectionFactory
            return new List<SelectListItem>
                new SelectListItem
                    Text = "Match",
                    Value = ((int)SearchValueCondition.Match).ToString()
                new SelectListItem
                    Text = "Starts With",
                    Value = ((int)SearchValueCondition.StartsWith).ToString()
Cheers
#77917
Nov 28, 2013 11:41
Hi Tim,
Why you don't keep calm and write down correct structure in your xml lang file?
Because you just follow by error message (Missing Text ...) is enough!
<?xml version="1.0" encoding="utf-8" ?>
<languages>
  <language name="English" id="en">
    <enums>
      <episerver>
        <templates>
          <alloy>
            <models>
                <startswith>Start With</startswith>
            </models>
          </alloy>
        </templates>
      </episerver>
    </enums>
  </language>
</languages>
Any way, if you just want to show it then ok! ;)
BR
Ha Bui
#77946
Nov 29, 2013 4:03
