Tuple<T1,T2> Problem with ImageEditor
Hello everyone, I have a problem with the ImageEditor. When I load a picture and try to change it (like resize for example), I'm using the options Constrain proportions and Save as a copy in Page files and Quality high (even though replace original yields the same result). I click apply, and then the OK button. Now instead of getting a "save as" dialog I just get a dialog with this error message:
Compiler Error Message: CS0433: The type 'System.Tuple<T1,T2>' exists in both 'c:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorlib.dll' and 'c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\495c83ab\dae76742\assembly\dl3\4124893d\00b1cf5d_d639ce01\System.ComponentModel.Composition.DLL'
Source Error:
Line 31:                         <ItemTemplate>
Line 32:                             <li>
Line 33:                                 <asp:HyperLink runat="server" Target="_blank" Text="<%# ((Tuple<string, string>)Container.DataItem).Item1 %>" NavigateUrl="<%# ((Tuple<string, string>)Container.DataItem).Item2 %>" />
Any ideas on how to resolve this? I feel like I can't think of anything else :-(
For reference I am using CMS 7.1.2 but also tried on 7.0.1, my app-pool runs .NET framework v4.0, i'm running windows server 2008 R2 Standard 64bit. I've tried these browsers: IE10, IE9, chrome and firefox.
The thing I tried that I had the highest hopes of working was this:
http://world.episerver.com/Articles/Items/EPiServer-CMS-60-now-supporting-ASPNET-40/
also noted here:
http://blog.nansen.com/2012/02/tuple-episerver-fail.html
As far as I can understand the problem is that there are two version of "Tuple" in the System namespace, one from System.ComponentModel.Composition.dll and one from mscorlib.dll. But how to get around this I have no idea! :(
Is there some fix from EPiServer possibly?
Regards
/Jonas
#76196
Oct 18, 2013 18:36
And yes, I have tried clearing the ASP.NET cache and browser cache without any result.
#76440
Oct 24, 2013 15:16
Finally I found the problem!! To make a long story short there was a version of the System.ComponentModel.Composition.dll referenced in my project. Everywhere I looked on the internets it looked like it should be that version also (2009.22.10.0), but of course It was not correct. Removing that file solved my issue.
Now I can only hope that my confused problem can help someone else :)
#77371
Nov 18, 2013 9:43
It helped me! Thanks!
#77827
Edited, Nov 26, 2013 23:07
Thanks for your sharing this secrete.
#77829
Nov 27, 2013 2:06
Thank you for posting the solution to this one :)
#151643
Aug 02, 2016 13:36
