Custom Property blocks Forms editing
Trying to implement the StringList Custom property from the Alloy example site in my own project. I have created/copied the PropertyStringList.cs, StringList.cs (EditorDescriptors), StringList.ascx and StringList.js (dojo) and the soultion builds ok. But when on a page that uses the StringList property I can't switch to Forms editing mode.
If I remove the StringList.cs (EditorDescriptors) the Forms editing works again. The only change i have made was to rename the ClientEditingClass in the StringList.cs and StringList.js.
Tried to activate the EpiServer log but even on All I can't get anything in the log when switching to forms editing.
Why does it not work?
#76345
Oct 22, 2013 14:52
Ok, found that the url to the js file is wrong when dojo tries to fecth it. The url becomes EPiServer/Shell/1.0.456/ClientResources/dtk/capo/editors/StringList.js.
How do I fix that.? Found the module.config file in the root that seems to have something to do with this but not really sure how.
#76346
Oct 22, 2013 15:11
And there comes the solution. Editing the module.config file to reflect my solution solved the issue.
#76347
Oct 22, 2013 15:29
