In the end I created a custom "ContentArea" model to override the creation of sub controls and I check each block to see if it's the last one in the set. If so, I add an extra CSS class :-) Not too hard in the end.
Hi guys,
Can you override the "ChildrenCssClass" property easily? I have a content area where the user can drag in blocks that all float to the left. The last item on the row I would like to add the class "last" to (to float right). How would I do this easily?
Chris
