Accessing name of block from view template
I have created a block called SectionTitleBlock with the following model and view:
    public class SectionTitleBlock : EPiServer.Core.BlockData
        public virtual string Title { get; set; }
[UIHint(Global.SiteUIHints.SectionIcon)] public virtual string Icon { get; set; } } public partial class SectionTitleBlockControl : BlockControlBase<SectionTitleBlock> { /// If the Title has not been set, return the name of the block as it was created in CMS. public string Title { get { if (String.IsNullOrWhiteSpace(this.CurrentData.Title)) { var content = this.CurrentData as IContent; if (content != null) return content.Name; } return this.CurrentData.Title; } } }
I want the Title property in the view to return the name of the block when the title has not been filled out by the user on the block.
I am trying to cast this.CurrentData to IContent to retrieve the name, however the cast results in null - looking at the inheritance of the classes and interfaces this looks correct not to cast correctly.
I can cast this.CurrentData to IContentData but that still does not provide me the name of the block as it was created in CMS.
Can anyone help?
Adam
#75869
Oct 09, 2013 12:53
It seems strange if you get a NULL when you cast your CurrentData to IContent.
The instance of the Block is in runtime created as a Proxy Class with IContent as a "mixin". Hence there are no programmatically relations with your BlockData and the IContent.
Note that this only works when you use your Block as a Shared Block, not if you add the Block as a Local Block (a Property on a Page).
#75873
Oct 09, 2013 13:29
Thanks Alf
I think that is the issue - I am using the block as a property on another block.
So as an example, I have a block called NewsList of which one of the properties is SectionBlockTitle.
From the Template of SectionBlockTitle, can I access the name of the parent NewsListBlock?
#75874
Oct 09, 2013 13:43
Maybe not otpimal but you could maye load in block instance.
var repository = EPiServer.ServiceLocation.ServiceLocator.Current.GetInstance<IContentRepository>();
IContent block = repository.Get<IContent>(content.ContentLink);
block.Name;
#75885
Oct 09, 2013 16:17
Per, what should "content" on your second row be?
In this case, the SectionTitleBlock is a local Block inside a Shared Block.
None the less, CurrentData on SectionTitleBlock cast to IContent will return null since it is a Local Block.
#75886
Oct 09, 2013 16:21
