If you are using EpiServer 7 you need to generate license for EpiServer 7, although the Episerver 6 license file contains Version=7.0.748.0, otherwise it throws the error
I am not sure that I understood your opinion correctly. I have a project which is based on EPiServer 6, I created a license for EPiServer 6, so I have gotten a license which contains Version=7.0. So I am not sure whether this is right license because I am getting license error when I execute a job. I do not get any license error when the project runs on IIS8, only when a job will be executed.
I'm wondering about the same. How is it possible to generate a CMS6 license without the 7.0 reference inside?
I created a partner developer license for CMS 6 but apparently the license is due to EpiServer 7 because it stands Version=7.0.748.0 inside the file license.config. I get EPiServer.Core.Licensing.Throw License Error, when I try to execute a job.
I took a look at teh inside of an older license on the same project on another pc where it stands version=6.2.165.1 inside. Is it wrong with license?
