How can I get all block within a folder progmmatically?
Dear all,
I have created a category called "Jobs" where I add all the "JobBlock" I create. I have a Folder named "Jobs" in the "Global Library" where I have already created 3 "JobBlock" {Job01, Job02, Job03} and I would like to know how can I get all those instances whithin the controller?
var categoryList = CategoryList.LoadCategories();
var categoryId = categoryList.FirstOrDefault(c => categoryList.GetCategoryName(c) == "Jobs");
How can I get a list of "JobBlock"s?
Best regards,
Daniel
#65251
Jan 23, 2013 17:51
Hmm, categories and block folders aren't related. To get all blocks in a folder you need a reference to the folder. You could for instance create a property of type ContentReference on the start page and have that point to the folder. Then you simply use the GetChildren method located on IContentLoader/IContentRepository/DataFactory with the reference as argument.
Getting all blocks categorized with a specific category is another question, but unless you actually need that, I would recommend using the above approach.
#65252
Jan 23, 2013 20:08
