Cannot create pages (Database problem)
Once upon a time, on our development database it become impossible to add new page. Button for that task are inactive. The only place that can be clicked is '+' button (Create content->New page) in the upper left corner. But then it displays page tree with description "Select where you want the page to be created." but I cannot click "select".
Its a problem with database, cause there is no problem on empty database or with staging database (full of content). I have found nothing helpfull in Admin Mode.
Can anyone point where in DB can I look for it?
#65476
Jan 30, 2013 16:08
Could it be related to access rights? If you go to admin mode and look at "Set Access Rights", does everything look as expected?
#65490
Jan 30, 2013 16:57
It was fine. I double checked and gave full access to everybody and everything, but still cannot create pages.
#65503
Jan 31, 2013 9:23
If you open up a clien side console, do you see any javascript errors?
#65507
Jan 31, 2013 9:36
Just a two Java Script Exception and one Warning from FB plugin ("Unsafe JavaScript attempt to access frame with URL ...."). But the same are when I can add pages, no difference here.
#65511
Jan 31, 2013 9:49
Do your config settings pageRootId and pageStartId on config element episerver/sites/site/siteSetting point to valid pages?
#65512
Jan 31, 2013 9:53
Yes they do.
pageRootId="1" pageStartId="4"
where 4 is existing FrontPage.
#65518
Jan 31, 2013 12:14
I have the same problem, the workaround is as follows :
Choose a simple page and copy it, then change its type to the one you want. Confirm that you will loose the data
Voila! a new page.
#76769
Nov 01, 2013 11:52
Nice, out of the box, idea @Null. Unfortunately it would not work for this case, as I was not able to create ANY page. Anyway, good tip to future!
#77304
Nov 15, 2013 10:50
I am having the same issue exactly - did you find a real solution for this problem?
Best regards
Rasmus
#118984
Mar 18, 2015 12:32
