Configuring editors for your properties
In EPiServer 7, you can configure custom editors for your properties, ref:
http://world.episerver.com/Blogs/Linus-Ekstrom/Dates/2012/9/EPiServer-7-Configuring-editors-for-your-properties/
But what if the drop down list items depends on property settings data?
I'm basically looking for a way to get the settings object (and still use the new ui), similar to this:
var settings = PropertyData.GetSetting(typeof(TagSelectorSettings)) as TagSelectorSettings;
I assume this can be fetched from the EditorDescriptor class or the meta data object, but I haven't found a method to use.
Anyone?
#65183
Jan 22, 2013 17:31
You can try casting the model to a PropertyData object. This is an extract of how we set up the Tiny MCE editor:
public override void ModifyMetadata(EPiServer.Shell.ObjectEditing.ExtendedMetadata metadata, IEnumerable<Attribute> attributes)
            //Grab property data
            var propertyData = metadata.Model as PropertyData;
if(propertyData == null)
{return;}//Always check for null after "as" statement
            //Load settings
            TinyMCESettings propertySettings = (TinyMCESettings)propertyData.GetSetting(typeof(TinyMCESettings));
#65188
Jan 22, 2013 20:30
Thanks, Linus! I'll try that. :)
#65282
Jan 24, 2013 15:00
