You can try to set following view data parameters before rendering content area with Html.RenderContentArea extension method; these values are used for custom tag, css class, children custom tag and children css class:
ViewData[EPiServer.Web.WebControls.RenderSettings.CustomTag] = "div"; ViewData[EPiServer.Web.WebControls.RenderSettings.CssClass] = "areaStyle" ViewData[EPiServer.Web.WebControls.RenderSettings.ChildrenCustomTag] = "span"; ViewData[EPiServer.Web.WebControls.RenderSettings.ChildrenCssClass] = "blockStyle";
Hi, Dmytro,
Nice news for me to get the day going, it works :)))
I have added this to the controller.
[HttpGet]
public ActionResult Footer()
if (StartPage != null)
var viewModel = new FooterViewModel
FooterContactBlocks = StartPage.FooterContactBlocks
ViewData[RenderSettings.ChildrenCustomTag] = "div";
ViewData[RenderSettings.ChildrenCssClass] = "footer-box span2";
return PartialView("Footer", viewModel);
return null;
I am not sure what I would do if I had two ContentArea with different rendering settings, probably I would need to create two views and controllers, but I guess that's fine.
Thank you very much!
Design breaks in edit mode, because @Html.EditAttributes renders extra two divs, so the divs are not floated.
See image:
http://img543.imageshack.us/img543/440/editmodebreaks.jpg
(The width of a surrounding div is 100%, so the edit box spans over it and it should only surround the red div. Hence divs look like they are one bellow another)
I would know how to fix this, if I was rendering the ContentArea on the page.
<div @Html.EditAttributes("FooterContactBlocks")> @Html.PropertyFor(m => m.FooterContactBlocks, new { ChildrenCssClass = "footer-box span2" }) </div>However, I am rendering it in Footer (a part of _Layout), so I can't use Html.PropertyFor and I am using:
<div class="row-fluid" @Html.EditAttributes("FooterContactBlocks")> @{ Html.RenderContentArea(@Model.FooterContactBlocks); } </div>How can I use RenderContentArea and specify children's CSS class?
