[bug?] Blocks disappearing from ContentArea's
I cannot give much more information. It appears that blocks sometimes go missing from ContentArea's. What could cause this? We are not changing the ContentAera's. Perhaps a property of a block, but that's about it.
#64513
Dec 24, 2012 16:41
Can it be that the block havnt been published? We will only show published content in the content areas.
#64517
Dec 26, 2012 8:10
I am running into this same issue.  I noticed it when changing a pagetype name as well.
#64556
Jan 01, 2013 0:42
We're having the same problem - the blocks are published. Appeared when we enabled "culturespecific" for contentareas, when changing the name of properties, but also in other cases that we haven't yet identified. This can potentially be a really big problem, so I hope that someone has a fix for this soon.
#64561
Jan 02, 2013 13:05
I will report this as a bug.
#64562
Jan 02, 2013 13:07
We found another way to replicate this problem. If you change the sortorder of a property on a pagetype or block manually in the admin mode it removes the block from the page. This is very easily done, since there's no warning before the sortorder changes, which has a large impact on the site. Very large amounts of content can dissapear, causing huge problems for everyone. Is there a hotfix coming out any time soon?
#64782
Jan 10, 2013 8:50
Timea, thanks for the update. We area looking into the problems and will hopfully have a fix for it soon.
#64783
Jan 10, 2013 8:55
Bug #93633: Blocks in ContentAreas are removed from the content area when the block is changed in code
#64983
Jan 17, 2013 9:28
Same problem here .. 50% of our content disappeared over christmas without trace!! not a very good bug to have in a enterprise CMS!!!
#79936
Jan 10, 2014 12:49
Matt: Which version do you run? The bugfix was made to the first patch of Release 7. If you get the latest patch from nuget, the bug will be fiexed.
#79937
Jan 10, 2014 13:08
Hi Jonas, thanks for the update, ill pass onto the dev team, but im being told we are running the latest patch
#79957
Jan 10, 2014 15:56
