I'm working on integrating a search provider and for that we are using a custom menu item. This worked fine in EPiServer 6, but in when upgrading to EPiServer 7 it no longer shows up at all.
What has changed since version 6 in regards to the episerver shell?
What I have found and fixed so far is that ClientResources moved from namespace EPiServer.Shell.Web.Mvc.Html to EPiServer.Framework.Web.Mvc.Html: http://world.episerver.com/Modules/Forum/Pages/thread.aspx?id=62721
However, even after fixing that the menuitem still won't show up. Here's what the code for the menuitem looks like:
.aspx:
using System.Web.UI;
using EPiServer.Shell.Navigation;
namespace Test.Navigation
[MenuSection( MenuPaths.Global + "/test", Text = "Test" )]
[MenuItem( MenuPaths.Global + "/test/manager", Text = "Manager", Url = "~/Admin/SitePlugin/TestManager.aspx" )]
public partial class TestManager : Page
Hello,
.aspx:
using System.Web.UI; using EPiServer.Shell.Navigation; namespace Test.Navigation { [MenuSection( MenuPaths.Global + "/test", Text = "Test" )] [MenuItem( MenuPaths.Global + "/test/manager", Text = "Manager", Url = "~/Admin/SitePlugin/TestManager.aspx" )] public partial class TestManager : Page { } }.aspx.cs:
<%@ Page Language="c#" Codebehind="TestManager.aspx.cs" AutoEventWireup="true" Inherits="Test.Navigation.TestManager" %> <%@ Import Namespace="EPiServer.Framework.Web.Mvc.Html" %> <%@ Register TagPrefix="sc" Assembly="EPiServer.Shell" Namespace="EPiServer.Shell.Web.UI.WebControls" %> <html> <head> <title>Test Manager</title> <%= Page.ClientResources( "ShellCore" ) %> <%= Page.ClientResources( "ShellWidgets" ) %> <%= Page.ClientResources( "ShellCoreLightTheme" ) %> <%= Page.ClientResources( "Navigation" ) %> <%= Page.ClientResources( "DojoDashboardCompatibility" ) %> </head> <body> <form id="form1" runat="server"> <sc:ShellMenu runat="server" ID="ShellMenu1" Area="CMS" /> <div class="epi-padding"> <iframe frameborder="0" style="width: 100%; height: 93%;" src="http://localhost:8080" /> </div> </form> </body> </html>in web.config/configuration/episerver.shell/protectedModules:
<add name="TestNavigation">
<assemblies>
<add assembly="Test.Navigation" />
</assemblies>
</add>
What do I need to change/add to get it to work in EPiServer 7?
