Try to remove the file Default.htm in the application root (that is the file that outputs "this installation only contains core files")
During some late night coding I ran into a stange problem I just don't understand...
I installed the Alloy demo out of the box and it worked fine. Then I did some changes in the source code and rebuilt the project in VS2012. Got some errors and found out that the following (and similar) row in CommonConfigTransforms was wrong:
<Import Project="$(MSBuildExtensionsPath)\Microsoft\VisualStudio\v10.0\WebApplications\Microsoft.WebApplication.targets" />
I changed to v11.0 due to my usage of VS2012. Got rid of the errors, but now when i browse http://locahost:17000 (where my demo site is installed....) i only reach the page that says that the installation only contains core files. http://localhost:17000/secure works fine to reach the dashboard though...
Please help, I'm not very familiar with build configurations...
Thank you in advance!
