Error when creating a new category
I'm trying to add a new category from  admin mode in cms 7.
I fill "name" and "description" and hit the save-button, and get this error:
Unable to cast object of type 'System.Web.UI.DataBoundLiteralControl' to type 'System.Web.UI.WebControls.TextBox'.
Exception Details: System.InvalidCastException: Unable to cast object of type 'System.Web.UI.DataBoundLiteralControl' to type 'System.Web.UI.WebControls.TextBox'.
Source Error:
Stack Trace:
[InvalidCastException: Unable to cast object of type 'System.Web.UI.DataBoundLiteralControl' to type 'System.Web.UI.WebControls.TextBox'.]
EPiServer.UI.Admin.Categories.Save_Click(Object sender, DataGridCommandEventArgs e) +458
System.Web.UI.WebControls.DataGrid.OnBubbleEvent(Object source, EventArgs e) +434
System.Web.UI.WebControls.DataGridItem.OnBubbleEvent(Object source, EventArgs e) +164
System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +84
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3804
Anybody has an idea why this happens?
/Anders
#63734
Nov 28, 2012 9:00
Strange. I tried it and could create both a new category and a subcatoegory below an already existin one with no problem.
Any special characters in any of the names? Have you tried to create a category with just an "a" as name and description?
#63746
Nov 28, 2012 13:35
