Addons option in site keeps flickering with the error message "unexpected token"
I've just installed a CMS7 on my Win2008R2 envirionment, and the add on store doesn't work. When accessing it through the site, it just keeps "flickering" and reloading the page with the error message "Error reading add-ons list Syntax Error: syntax error, unexpected token <". The page is reloading with a 1 second interval, so I need to go to another URL.
Is this something anyone have experienced ?
#63466
Nov 20, 2012 15:26
Hello Andreas,
Could you check (with Firebug for example) which request is failing and what the response of the failing request contains.
#63479
Nov 20, 2012 16:17
What do you have in episerver.packaging section in web.config?
Could you try to check the POST request and URL when add-on system tries to read the list of installed add-ons? The URL should look like http://siteurl/pathtoUI/AddOns/AddOns/GetInstalledModules?moduleArea=EPiServer.Packaging.UI
Fiddler, Firebug or Web INspector should be good tools for that.
#63481
Nov 20, 2012 16:22
