GetDidYouMean
Hi Friends
I want to implement GetDidYouMean with size attribute. Can you provide me with a sample code?
Syntax: GetDidYouMean(string query,Action)
#152314
Aug 23, 2016 22:09
here is an example:
SearchClient.Instance.Statistics().GetDidYouMean("hi there", x => x.Size = 10);
You can also use:
 SearchClient.Instance.Statistics().DidYouMean("hi there", 10);
#152317
Edited, Aug 24, 2016 7:52
Thanks Magne... "GetDidYouMean" works...
Initially I used "DidYouMean" and it always returns 0 results for me, i even updated latest FIND DLL. Its ok.. I will use "GetDidYouMean"
If possible can you tell me the differance between "GetDidYouMean" and "StatisticsDidYouMean" ?
#152488
Edited, Aug 24, 2016 15:20
StatisticDidYouMean is just a wrapper for DidYouMean, with the default tags set and size set to 1:
    public static DidYouMeanResult StatisticsDidYouMean(this IStatisticsClient client, string query, int size = 1, IEnumerable<string> tags = null)
      return client.GetDidYouMean(query, (Action<DidYouMeanCommand>) (x =>
        x.Size = new int?(size);
        x.Tags = StatisticsClientExtensions.AddDefaultTags(tags);
#152548
Aug 25, 2016 8:20
Thanks a lot Magne.
#152587
Aug 25, 2016 16:02
