Hi Jeremy,
If I understand correctly you are just wanting to add:
<script nonce="rAnd0m">
To the inline scripts in forms?
There are 2 ways I can think of to do this.
Option 1 - Modify the forms views, you will need to find the views in the forms.zip in the modules folder, extract these and then you can edit as you please.
Option 2 - If I am right the scripts will be added as part of the FormContainer, you could create your own and then modify as you wish.
Other info that will help also https://docs.developers.optimizely.com/content-management-system/docs/content-security-policy
Paul
Thanks Paul - I believe that is part of the solution, however there are other scripts injected on the page. I think I have just found a solution:
https://world.optimizely.com/blogs/giang-nguyen/dates/2021/7/get-rid-of-episerver-forms-in-line-scripts/
Hey Jeremy,
There is an alternative though would not suggest, you can disable the us of JS in Forms, though you then have limited functionality.
Paul
Is it possible to create a strict content security policy using a nonce directive on inline script elements added from Optimizely Forms?
