Can I change the id attribute on the form container section and on the form input fields?
We sometimes have more than one form on a page and the generated id's for Epi forms are the same for each form so if there are 2 or more forms on a page, you end up with duplicated id's which is an accessibility issue, not to mention a bad practice.
For example:
<section id="__field_"
Inputs:
<input id="c3d65aff-af7b-4496-aa59-65011b2a2914" - the id gets repeated for the same field if another form is added.
Are these id's used internally in Epi forms logic? Can they be removed/changed?
#313912
Edited, Dec 08, 2023 17:23
No, that would break a lot of things.
#314037
Dec 11, 2023 12:09
This creates an accessibility issue, not to mention it's poor html -  Optimizely is ok with that?
#314603
Dec 23, 2023 14:50
