Episerver form items dissapearing from dependencies
I have a problem with selection form items. When I moved it to shared form items all the dependencies fields list on condition details is empty. Is there any way around it? It looks similar to https://world.optimizely.com/blogs/kennyg/dates/2019/4/gotchas-with-reusing-episerver-forms-elementblocks/
Best Regards,
Bartosz
#259230
Jul 21, 2021 11:14
Maybe I wasn't clear enough.
Lets say I ahve a form like this:
And obviously I can edit the dependencies.
Now I'm moving the SelectionTest from ForThisBlock folder into ForThisSite (or other shared block folder) it looks like this:
Of course the form looks the same as above after this action
And the Select dependent field window is empty as above.
Do you have any ideas if this can be fixed? One workaround is to move the selection block back to for this block and edit it, and then move it. But it is not intuitive :)
#259346
Edited, Jul 23, 2021 8:24
