Not with OneTrust, but with another similar solution.
Simply override the FormContainer, check if cookies consent if given. If no consent, show a message telling the user "form unavailable until consent is given" instead of the form.
For any future readers - here's an alternative that I was able to throw together based on this page https://docs.developers.optimizely.com/content-cloud/v1.2.0-forms/docs/how-cookie-works
I've done some basic tests and it seems to work.
(Edit: Note that this implementation uses Optimizelys internal API)
[ServiceConfiguration(typeof(IVisitorIdentifyProvider))]
public class CustomVisitorIdentifyProvider : DefaultVisitorIdentifyProvider
private static readonly object _lock = new object();
/// <summary>
/// Optimizely Container will scan in all assemblies to find out which Implementation will get executed.
/// If there are multi-implementations, class with lowest Order will be executed. The Order of DefaultVisitorIdentifyProvider class is 1000.
/// So we have to set this value to 1 (as long as lower than 1000)
/// </summary>
public override int Order
get { return 1; }
public override string BuildVisitorIdentifier(string browserID, string userID)
// TECH NOTE: When access cookies from multi threads, sometime it throw exceptions even we use lock for synchronizing.
// So that we need surround code with try/catch to make sure the exception does not break the request.
lock (_lock)
try
var cookieConsent = Context.Request.Cookies["CookieConsent"];
if (cookieConsent?.Value != "1")
return string.Empty;
return base.BuildVisitorIdentifier(browserID, userID);
catch (Exception)
/// <summary>
/// Set form cookie.
/// </summary>
public override string GetVisitorIdentifier()
lock (_lock)
try
return base.GetVisitorIdentifier();
catch (Exception)
public override void SetVisitorIdentifier(string visitorIdentifier)
lock (_lock)
try
return;
base.SetVisitorIdentifier(visitorIdentifier);
catch (Exception)
// ignored
Hi, I'm implementing OneTrust integration for my client and I encountered one problem. There are cookies categorized as functional ones, related to EpiForms:
.EPiForm_VisitorIdentifier, .EPiForm_BID, EPiForm_{FormGuid}
is there any way to dynamically set if cookies should be stored (based on user consent)? I only found suggestion of setting cookie expiration day to -1, but it would turn cookies off in general. I want to avoid that. Is there anybody out there, who already walked through such change?
