Rate limiting on form submission.
I'm looking into whether it is possible to rate limit the submission of a form. At the moment it is possible to use the Forms Criterion and a visitor group to prevent a user from submitting a form twice.
The question here is what to do in case the user should be able to keep submitting a specific form.
What I would be looking for ideally is to be able to limit the rate of a user to x/hour or x/day.
Any ideas?
Thank you!
#248081
Feb 03, 2021 14:06
One option...
  • Create an InitializableModule and subscribe to FormsEvents.OnSubmitting
  • If needed, add data (i.e. ip-adresss) to identify the user to the formsubmission
  • Check if set rate is exceeded, if it is then set CancelAction and CancelReason
#248082
Feb 03, 2021 14:40
