Trigger autofill of form elements when editing another element.
What is the best way to add/change values of form elements when editing/changing another element?
The AutofillProviders method "GetSuggestedValues" only seems to run on initializing the form, is it possible to trigger the method thru api?
I could of course do it with my own javascript and backend api but I would like to make use of EPiForms built in functionality as mutch as possible.
Anyone have any iées?
Regards
/Jesper
#216369
Feb 05, 2020 7:30
As I know, Forms does not have api for doing that. You need to write your own code to change value when another element changed.
#216435
Feb 06, 2020 9:25
