Yes! :-)
Have a look at the documentation for custom for actors, and notice that you are able to cancel a form submission and display an error message.
https://world.episerver.com/documentation/developer-guides/forms/implementing-a-customized-actor/
I did something simular by creating a custom actor to detect URLs in our form which you could modify to check for emails
public class FilterURLActor : PostSubmissionActorBase, ISyncOrderedSubmissionActor
public int Order => 1;
public override object Run(object input)
var result = new SubmissionActorResult { CancelSubmit = false, ErrorMessage = string.Empty };
foreach (var i in this.SubmissionData.Data)
if (FormsHelper.HasURL(i.Value.ToString()) && i.Key.ToString().Contains("field") && !i.Value.ToString().Contains("@"))
result.ErrorMessage = "Error: URL in form.";
result.CancelSubmit = true;
return result;
I'm using a helper class called FormsHelper.HasURL(i.Value.ToString()) which I use to detect a URL. I aslo have one for emails - this is the code I'm using. I know the regex for emails are... fun
public static bool isProperEmail (string s)
s = Regex.Replace(s, @"\A(?:[a-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[a-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[a-z0-9](?:[a-z0-9-]*[a-z0-9])?\.)+[a-z0-9](?:[a-z0-9-]*[a-z0-9])?)\Z", "[[Email]]");
if (s.Contains("[[Email]]"))
return true;
else
return false;
Anyway, this probably isn't the most elegant solution but it works.
Hi Guys,
I have an issue: I am looking for a way that someone can only fill in a form just once and based on emailadress. So if you fill in a form that you have already filled in in the past, you are receiving an error (this emailadres already exists for example).
Is it possible to validate on emailadress if someone filled in the form already?
