Hi Drew,
We don't have sufficient permission to test with CustomObject on Salesforce portal. I forward your question to other teams.
Hi Drew
The Salesforce connector only supports standard objects as listed. For custom objects, yes, it would have to be a custom implementation.
When creating a form with the Salesforce Marketing Connector (EPiServer.MarketingAutomationIntegration.Salesforce v4.2.0) I only see the standard Salesforce Objects (Accounts, Contacts, Leads, Cases, and Campaign). Is there any way to submit forms data to a CustomObject that was created through the salesforce web UI using the connector? Or, do I need to create my own rest client to do that?
