Hi Noel
The Episerver Forms samples code has a date/time element that you might be able to use for inspiration: https://github.com/episerver/EPiServer.Forms.Samples
David
Thanks David, browsing that code showed me "AvailableValidatorTypes" (which is the answer I needed)
my element's full *.cs file source:
[ContentType(DisplayName = "Date Picker", GroupName = "Basic Elements", GUID = "...")]
[AvailableValidatorTypes(Include = new Type[] { typeof(RequiredValidator) })]
public class DateElementBlock : TextboxElementBlock
public DateElementBlock() : base() { }
[ScaffoldColumn(false)]
public override string PredefinedValue { get { return base.PredefinedValue; } set { base.PredefinedValue = value; } }
public override string PlaceHolder { get { return base.PlaceHolder; } set { base.PlaceHolder = value; } }
I'm making a custom Form Element of "Date" type, so I'm extending "TextboxElementBox" like so...
My custom element will be
but because I'm extending TextboxElementBlock the editor displays a few validation options...
which are not appropriate. I did TRY and create a custom element with a custom validator, but the client side custom error message is not displayed correctly, so I figured as the browser will ensure that the "date" field will have a proper date if it has anything in it at all, so If I could remove all the validation options above except the "Required" validator then my problem would be sorted.
I tried to override the value returned by
inside
DateElementBlock.cs, but that only returns a list of ACTIVE validators, so it doesn't control the list of validators presented to the editors.I think this may require a dojo solution, and I've already inspected the zip files (EPiServer.Forms.zip and EPiServer.Forms.UI.zip) and I'm hoping it works similar to adding a custom element (copy ascx/js file from zip into correct folder location).
Anyone done anything similar in the past?
