Email validation in forms
I have a problem with the following is being logged "[..namespace...] : Could not send email because the specified recipient email is not a valid email address in the block with ID 44164".
It seems that the frontend validation is not as strong as the backend. You can write "something@something.dk2" in the frontend, but in the backend you will get the error message.
The backend validation (System.ComponentModel.DataAnnotations) EmailAddressAttribute IsValid regex is the following:
^((([a-z]|\\d|[!#\\$%&'\\*\\+\\-\\/=\\?\\^_`{\\|}~]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])+(\\.([a-z]|\\d|[!#\\$%&'\\*\\+\\-\\/=\\?\\^_`{\\|}~]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])+)*)|((\\x22)((((\\x20|\\x09)*(\\x0d\\x0a))?(\\x20|\\x09)+)?(([\\x01-\\x08\\x0b\\x0c\\x0e-\\x1f\\x7f]|\\x21|[\\x23-\\x5b]|[\\x5d-\\x7e]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])|(\\\\([\\x01-\\x09\\x0b\\x0c\\x0d-\\x7f]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF]))))*(((\\x20|\\x09)*(\\x0d\\x0a))?(\\x20|\\x09)+)?(\\x22)))@((([a-z]|\\d|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])|(([a-z]|\\d|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])([a-z]|\\d|-|\\.|_|~|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])*([a-z]|\\d|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])))\\.)+(([a-z]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])|(([a-z]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])([a-z]|\\d|-|\\.|_|~|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])*([a-z]|[\\u00A0-\\uD7FF\\uF900-\\uFDCF\\uFDF0-\\uFFEF])))\\.?$
Whereas the AvailableValidatorTypes EmailValidator on the block is only:
(^$)|(^[a-zA-Z0-9_.+-]+@[a-zA-Z0-9-]+\\.[a-zA-Z0-9-.]+$)
Is there a way to make the two validations the same so the user does not insert a invalid email?
#201311
Feb 13, 2019 10:35
I think there is no way to change email validations in this case. This problem is come from  built-in form actor - SendEmailAfterSubmissionActor, there is no validation in the EmailTemplateActorModel when adding ToEmails list but when separating ToEmails and add into SMTP message then these emails are validated. Unfortunately we have no way to override SendEmailAfterSubmissionActor
#201341
Feb 15, 2019 3:39
