New Custom Form Elements not available in UI
This is a weird one that just started happening and I am at a complete loss. I create a new custom form element block in code but it is not being picked up by the UI. It's not in the Form Elements gadget and it is not listed when you click "create a new form element".
The View is in the right location.
Now when you go under Admin > Content Type > Block Types you can see the info and everything looks fine.
Even if I make a copy of an existing element (add a 2 to the name, generate a new GUID) that copy won't show up either.
Thoughts??
#211206
Dec 19, 2019 21:30
Can you try to move your element to fresh Alloy site to see if it shown. One reason that you could consider is caching of ASP.NET. Try to clear the folder C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files (correct your path) and refresh the site.
#211266
Dec 24, 2019 10:44
- Dec 27, 2019 17:53
Dac, it seems to be some problem in the database because I have copied down the INTE database and now the block is appearing.
Yeah, I replaced my local database with a backup from Integration and the problem went away. Super weird.
#211283
Dec 27, 2019 18:01
