Hello!
Im building a custom forms actor which will make a service call to our customer support system. One of the parameters which is required by support system is customer email.
At the moment I have an kind of ugly solution with a "NameOfEmailField" string property on actor where you have to add name of forms element where user supplies email. In actor implementation I match value from "NameOfEmailField" with form elements and add value to service call.
I would like a solution where instead of having a free text field you can choose which forms element from a dropdownlist based on elements in current form which matches customer email. I have played around with a SelectOneAttribute and ISelectionFactory but it seems I only get hold of the actor, not the form on which the actor is added. Has anyone managed to solve this?
This is what im trying to achieve:
