are you modifying the language file for Forms? Could you check if your site have xml language file contains:
<episerver.forms.implementation.validation.regularexpressionvalidator>
<displayname>Regular expression</displayname>
<message>This field should be in "{0}" format.</message>
</episerver.forms.implementation.validation.regularexpressionvalidator>
That was it - Thank you Dac Thach Ngyen! It turned out to be a problem with a forms language file that only excisted in production.
if i use the regular expression validator on a text field in epi forms, I get an exception:
This happens only in the production environment, it works in stage and local.
I have made sure the modules folder, bin folder and web.config is the same. I can't see any custom validators. Any clue what could cause this?
