Forms not working after upgrade.
We have recently upgraded our site to all latest versions, ( using 4.10.0.0 Forms). everything is running fine.
But when we go to submit a form, it doesnt work, wont send and content stays there and the submit button is then disabled.
It is throwing an 500 Error. for WebResource.axd
Below is error log from console:
Uncaught ReferenceError: returnedResult is not defined
at Object.error (WebResource.axd?d=TzRGlCddaaqtz0Im2nSJhHrt-7BfQVv8aewHqDIt8H9HhsHFbim15giBKNYgkK3zBUVFaaVgAafS1Ic-2qfR1yHDFAs3j50CVpNuVScuuIL3-n5XHDCRPS-3DVQhlbo5irDy-WDgbsetAXbOGlqmlzW9a1JQQr4dzC6Z34vFxDQ1&t=636572251696406253:1)
at i (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:2)
at Object.fireWith [as rejectWith] (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:2)
at y (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:4)
at c (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:4)
at Object.send (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:4)
at Function.ajax (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:4)
at b (WebResource.axd?d=TzRGlCddaaqtz0Im2nSJhHrt-7BfQVv8aewHqDIt8H9HhsHFbim15giBKNYgkK3zBUVFaaVgAafS1Ic-2qfR1yHDFAs3j50CVpNuVScuuIL3-n5XHDCRPS-3DVQhlbo5irDy-WDgbsetAXbOGlqmlzW9a1JQQr4dzC6Z34vFxDQ1&t=636572251696406253:1)
at Object. (WebResource.axd?d=TzRGlCddaaqtz0Im2nSJhHrt-7BfQVv8aewHqDIt8H9HhsHFbim15giBKNYgkK3zBUVFaaVgAafS1Ic-2qfR1yHDFAs3j50CVpNuVScuuIL3-n5XHDCRPS-3DVQhlbo5irDy-WDgbsetAXbOGlqmlzW9a1JQQr4dzC6Z34vFxDQ1&t=636572251696406253:1)
at Object. (WebResource.axd?d=rQapnFTl_pgMjn3yGS-nPus3_Ja1e7HwXkCMLpKmaI7wZtHbJt38lnerKJxtyh3ABWW8wA2wg23b55RyX--7SPFC_amSZ4s3kHjbIHjZ5ZcUe0-hIRv22DW_HSHeJm2h1VlDugpfPvp8B46NNEnr4xuoNiQlUos9fT4blyY89Cw1&t=636572251696406253:2)
#191127
Apr 20, 2018 15:01
Do you have any custom code on the submit button that may interfere with the FormsMvcRouteHandler?
#191148
Apr 20, 2018 20:32
The code has not been change since the upgrade, so no costom code, as far as i am aware:
<button type="submit" name="submit" value="<%: SubmitButtonType.NextStep.ToString() %>" class="Form__NavigationBar__Action FormExcludeDataRebind btnNext" <%: nextButtonDisableState %>><%: Html.Translate("/episerver/forms/viewmode/stepnavigation/next")%></button>
#191169
Apr 23, 2018 10:33
if you browse to given link directly - what's being returned?
#191208
Apr 24, 2018 7:27
Please show the description of error 500 along with stack trace, so we can detech what wrong with your forms.
#191212
Apr 24, 2018 9:18
valdis iljuconoks if i navigate to the webResource.asxd?
i get:
(function(n){if(typeof epi=="undefined"||typeof epi.EPiServer=="undefined"||typeof epi.EPiServer.Forms=="undefined"){console.error("Forms is not initialized correctly");return}if(typeof n=="undefined"){console.error("Forms cannot work without jQuery");return}var t=epi.EPiServer.Forms.Utils,i=epi.EPiServer.Forms.Data,r=epi.EPiServer.Forms.Extension,u=epi.EPiServer.Forms.Validation,f=epi.EPiServer.Forms.Navigation;epi.EPiServer.Forms.__DebounceTimer=null;epi.EPiServer.Forms.__Initialized=!(epi.EPiServer.Forms.__Initialized===undefined);n.extend(!0,epi.EPiServer.Forms,{Utils:{debounce:function(n,t){return function(){var i=this,r=arguments;clearTimeout(this.__DebounceTimer);this.__DebounceTimer=setTimeout(function(){n.apply(i,r)},t)}},loadExternalScriptOnDemand:function(n,t,i){for(var o=document.getElementsByTagName("head")[0],u=0,f=n.length,e=null,r;u<f;u++)e=n[u],r=document.createElement("script"),r.type="text/javascript",r.async=i||!1,r.defer=i||!1,r.src=e,o.appendChild(r),u===f-1&&this._setupCallback(r,t)},loadExternalCssOnDemand:function(n,t){for(var e=document.getElementsByTagName("head") ...
Dac Thach Nguyen
Below is the Error log when the form is sumbited:
2018-04-24T07:33:10,Error,tsfg01ze518inte,ab2877,636601519900979825,0,9424,9,"EPiServer.Forms.Internal.Security.DefaultAntiForgeryValidator : Failed to validate the anti-forgery token
System.Web.Mvc.HttpAntiForgeryException (0x80004005): The required anti-forgery cookie "__RequestVerificationToken" is not present.
   at System.Web.Helpers.AntiXsrf.TokenValidator.ValidateTokens(HttpContextBase httpContext, IIdentity identity, AntiForgeryToken sessionToken, AntiForgeryToken fieldToken)
   at System.Web.Helpers.AntiXsrf.AntiForgeryWorker.Validate(HttpContextBase httpContext, String cookieToken, String formToken)
   at EPiServer.Forms.Internal.Security.DefaultAntiForgeryValidator.Validate(HttpContextBase httpContext)",
#191244
Apr 24, 2018 16:01
if you are overriding forms block template, then you might be missing anti-forgery token added to the request.
<%= Html.GenerateAntiForgeryToken(Model) %>
#191245
Apr 24, 2018 16:23
Thanks this worked valdis iljuconoks
#191255
Apr 24, 2018 17:44
