Forms elements drag and drop problem
We have encounter an problem with d&d form elements. It occurs only when we select to add new forms container by selecting "create new block" on content area.
Then form elements drag and drop into Form elements container don't work, nothing is happening. No indication or console error.
Is this an known issue?
We are using forms in v4.3.0
#191748
Apr 27, 2018 11:11
Is there an error in the logs?
#191788
Apr 27, 2018 18:09
Tomas Hensrud Gulla
I've experienced the same with regular blocks created with the "create new block" link below the content area. Publishing the page with the content area make the drag and drop start working again.
I was unable to reproduce the problem on the lates version of the Alloy site. My point: not sure if it's related to Episerver Forms, it could be a general problem with blocks.
#191806
Apr 29, 2018 20:30
@Aniket no, error logi is empty
@Tomas Hensrud Gulla, yes after save action d&d worls fine, but unfortunately this is not an solution :)
#192100
May 07, 2018 12:12
https://jira.ep.se/browse/AFORM-938. It's exactly what you are experiencing.
This bug was fixed in EPiServer.Forms 4.9.1.
#192318
May 15, 2018 11:46
Thank You for info
#192390
May 16, 2018 10:03
