Hi Patrick,
The documentation is here: https://world.episerver.com/documentation/developer-guides/forms/
I don't know any other better way to accomplish that. And i ve never build forms from code.
My favorite regarding retrieving data from submission is through webhooks https://world.episerver.com/documentation/developer-guides/forms/implementing-a-customized-actor/webhooks-actor/
but you do also have the service api https://world.episerver.com/documentation/developer-guides/forms/using-forms-serviceapi/
Ive also blogged randomly about forms http://devblog.gosso.se/tag/episerver.forms/
Good luck!
Luc Gosso
Thanks for the reply. I had seen that documentation link already, but it doesn't cover much as far as interacting with data (and even less about how to create instances of forms via the API). I guess I will continue on the path I was on. I was hoping I was missing a built-in API for creating forms...but I guess not.
For anyone else that may need this in the future, I finally got around to doing a write-up on using the API to create froms.
Patrick,
This is a great blog post. Would you be willing to share it on Epi World under Blogs? See https://world.episerver.com/System/Blog-info/Episerver-World-Blog-Rules/.
To help simplify the initial deployment of a site, I'm trying to automate the process of creating a few forms. I'm finding this process to be rather tedious, and am hoping there is an easier solution.
From what I've read in the documentation (which is extremely limited) and some blog/forum posts, forms are based on the concept of blocks, and can be created as such via IContentRepository. So long as I put these new instances of FormContainerBlock where Forms is expecting them (ContentReference.GlobalBlockFolder -> "Episerver Forms"), it seems to work as expected. However, adding fields to the form appears to require creating instances of the FormElement blocks I need (text, number, etc.), and putting them in the "For this block" folder (at least, that appears to be what Forms does out of the box). I haven't tested this fully yet, but I don't see any reason why it wouldn't work.
Is there a better way to accomplish what I'm trying to do? It's been basically "guess an check" so far, which is unfortunate and time consuming. I see the IFormRepository and IFormDataRepository, but they offer very limited funcitonality related to retrieving data from forms/submissions. If it doesn't already exist, I think having a proper API for interacting with Forms would be very helpful.
Also, there doesn't appear to be any real "developer documentation" for Forms. Is this something that is on the roadmap? Having to dig through source code and random forum posts isn't a very productive way to work...
