Hmm, I tried the following code but see no problem
public override Guid SaveToStorage(FormIdentity formIden, Submission submission)
var dds = new DdsPermanentStorage();
var submissionId = dds.SaveToStorage(formIden, submission);
submission.Data["__field_183"] = "test@test.test"; // __field_183 is the id of my hidden visitor profiling field
dds.UpdateToStorage(submissionId, formIden, submission);
return submissionId;
Thanks Phu. I changed my code to use var submissionId = ddsSubmission.SaveToStorage(formsIden, submission); but it still gives the error {"Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx)."}.
I'm wondering if there is a permission or property in the web.config related to this method that I haven't set.
The code that I'm using gives an error - {"Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx)."}
I've tried -
var ddsSubmission = new DdsPermanentStorage();
* code here to get the correct field, remove it, and re-add it to the submission object with the updated values.
ddsSubmission.UpdateToStorage(formGuid, formsIden, submission);
as well as -
ddsSubmission.SaveToStorage(formsIden,submission)
but in both cases I get the same error.
This error appears to be related to the Guid that's part of formsIden but I use formsIden to get the friendlynames and it works.
