External system integration - mappings disappear
I've tried out the External system integration and got it to work but whenever the site is restarted/rebuilt the mappings disappear which makes the functionality useless. Any pointers on where to look or is this just a bug?
#188816
Mar 05, 2018 8:10
When mapping is saved, it is stored into a property of the FormContainerBlock. So it should be there when you do restart/rebuild. Do you have custom the editor for that mapping? Or do you return consitent data from your ExternalFieldMappingService?
#188817
Mar 05, 2018 8:25
The following is the class used for the mapping/autofill:
public class CustomerDataAutofill : IExternalSystem, IAutofillProvider
        public string Id => "CustomerDataAutofill";
        public IEnumerable<IDatasource> Datasources
            get
                var datasource = new Datasource()
                    Id = "ContextCustomerInfo",
                    Name = "Kontextbaserad kunddata",
                    OwnerSystem = this,
                    Columns = new Dictionary<string, string>
                        {"FirstName", "Förnamn"},
                        {"LastName", "Efternamn"},
                        {"EMail", "E-post"},
                        {"Phone", "Telefonnummer"},
                        {"Address", "Adress"},
                        {"PostalCode", "Postnummer"},
                        {"City", "Ort"},
                return new[] { datasource };
        public IEnumerable<string> GetSuggestedValues(IDatasource selectedDatasource, IEnumerable<RemoteFieldInfo> remoteFieldInfos, ElementBlockBase content,
            IFormContainerBlock formContainerBlock, HttpContextBase context)
            if (selectedDatasource == null || remoteFieldInfos == null)
                return Enumerable.Empty<string>();
            if (!this.Datasources.Any(ds => ds.Id == selectedDatasource.Id))  // datasource belong to this system
            var activeRemoteFieldInfo = remoteFieldInfos.FirstOrDefault(mi => mi.DatasourceId == selectedDatasource.Id);
            if (activeRemoteFieldInfo == null) return Enumerable.Empty<string>();
            var currentUser = ServiceLocator.Current.GetInstance<ICurrentUser>();
            var restService = ServiceLocator.Current.GetInstance<IRestService>();
            switch (activeRemoteFieldInfo.ColumnId)
                case "FirstName":
                    return new List<string> {
                        currentUser.FirstName
                case "LastName":
                        currentUser.LastName
                case "EMail":
                        currentUser.Email
                case "Phone":
                    var phonenumber = restService.GetContactById(currentUser.ContactId).Telefonnummer1;
                    if (string.IsNullOrWhiteSpace(phonenumber))
                        phonenumber = restService.GetContactById(currentUser.ContactId).Telefonnummer2;
                       phonenumber
                case "Address":
                        restService.GetContactById(currentUser.ContactId).Folkbokforingsadress.StreetAddress
                case "PostalCode":
                        restService.GetContactById(currentUser.ContactId).Folkbokforingsadress.ZipCode
                case "City":
                        restService.GetContactById(currentUser.ContactId).Folkbokforingsadress.City
                default:
#188865
Mar 06, 2018 9:47
I have tried your class with Forms and the mappings are still there when I rebuild/restart the site. Are you running custom code to clear/create new database?
#188871
Mar 06, 2018 10:10
Reason for the failures is unknown. We believe a faulty synchronization between servers could have been a reason but we are not really sure. It is working now anyway. :)
#189928
Mar 27, 2018 14:49
