episerver form version compatibility
Hello,
I am on Episerver version 10 and the latest form version I can get is 4.8. The thing is it messes up the css for me for forms in the edit mode. How do I check the compatibility, meaning which version supports which one?
#189018
Mar 08, 2018 17:38
According to https://world.episerver.com/releases/episerver---update-190/, EPiServer.Forms version 4.9.0 has support for CMS 11. So subsequent versions also support CMS 11.
According to https://world.episerver.com/releases/episerver---update-135/, EPiServer.Forms 4.1.0 has support for CMS 10. So versions between 4.1.0 and 4.9.0 support CMS 10.
#189027
Mar 08, 2018 22:03
You can also check the dependencies in the Episerver Nuget feed. Click each version of the Forms.Core version history to see which version of Episerver.CMS.Core is supported:
http://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.Forms.Core
#189029
Mar 08, 2018 22:45
So my version of episerver is 10.2 and forms are 4.6.1 and then in the edit mode of form container the form elements overlap with the add more elements here div.
I’m trying to upload a picture of that here but not sure how because the editor won’t let me upload a picture
#189032
Mar 09, 2018 6:08
The thing is it is working properly but only the ui is having issues. It doesn't apply bootstrap. Do you guys know how to add an image here maybe that will help?
Or maybe you can have the look at the image here at Stackoverflow
https://stackoverflow.com/questions/49171865/episerver-form-container-render-issue?noredirect=1#comment85350233_49171865
#189034
Mar 09, 2018 7:29
I found out that epi-editContainer for some reason has a min-height of 26px. That is making it look funky. Any ideas?
#189038
Mar 09, 2018 8:39
Chaudhry,
Here are instructions for uploading an image into a World forum post.
Prerequisite: The image you want to post exists on your computer
  1. Open the website https://imgbb.com/.
  2. Upload the image to be inserted.
  3. From the Embed codes dropdown, choose "HTML full linked."
  4. From that code's img src property, copy the image path beginning with https. For example, https://preview.ibb.co/ffn6oQ/room_finder.png
  5. Go to the forum post.
  6. Click the Insert/edit image button.
  7. Into the dialog's Source field, paste the path you copied in Step 4.
  8. Complete the dialog and click OK.
#189068
Mar 09, 2018 15:27
