Translating - Multiple or single choice field
Currently on a multi language site we want to use a Multiple or single choice field. However the items are not translatable in a different language. At least the choice how it is displayed in the front-end should be translatable as this might need to differ per language. Is this something that will be built-in in future releases?
#199647
Dec 04, 2018 12:09
Hi Jeroen,
As I know there is no built-in property for this. You can work around by using Enum type and add xml translations for appropriated enum.
Here is the reference link https://world.episerver.com/blogs/russell-mercer/dates/2015/1/post-title/.
When displaying the choosen value then you should get translated value instead of real value
#199748
Dec 10, 2018 7:54
Thanks, that similar approach we already used at some blocks. However that requires some custom form elements to create this functionality within EPI Forms unfortunately.
#199844
Dec 13, 2018 16:02
Jeroen,
You could submit this as a feature request in this forum: https://world.episerver.com/forum/developer-forum/Feature-requests/
#199845
Dec 13, 2018 16:23
you could give a try for db localization provider (that supports enum based properties) - https://blog.tech-fellow.net/2018/12/29/localized-episerver-enum-properties/
at least it translates values for specific languages for episerver admin ui, I'm a bit off the ring how it was implemented for forms tho... so just a speculations here.
#200069
Dec 30, 2018 3:44
