Episerver forms - post form data without page reload
I'm planning to use Episerver forms on a page to gather information from the visitor regarding their purpose for visiting.
This will be shown as a small popup on the page. I want to use Episerver forms for this because of the ease of creating different forms and storing the data.
I did however notice when testing Episerver forms that when submitting the page reloads. I would like some pointer on what options I have to be able to submit the data without the page reload. Do I need to create a custom controller or would hooking in to one of the existing events suffice?
All input or help is greatly appreciated.
Thanks!
#187558
Jan 26, 2018 8:03
By default Forms using ajax to submit user data, no reload page necessary. Please check the file Forms.config contain this line:
workInNonJSMode="false"
Then try to restart site.
Hope this help.
#187577
Jan 29, 2018 8:41
workInNonJSMode was already set to false unfortunatly.
I have Episerver forms 4.6 installed, could it be a version issue?
#187578
Jan 29, 2018 8:56
Please check your browser if it support js. And open dev tool to see XHR requrest send to server. Can you try on fresh site with Alloy template?
#187579
Jan 29, 2018 9:00
I'm using latest version of Chrome and Firefox and have no addons or extensions to block js.
There are no XHR-requests sent when clicking submit, the page reloads.
Will test with a fresh Alloy and get back with results.
#187580
Jan 29, 2018 9:28
Check if you make the form display a page after submitting. The redirecting can be set in "All Properites" mode of Forms or Submit button.
#187581
Jan 29, 2018 9:34
I did not use the redirecting property on the formcontainer or the submit-button.
It works fine in an Alloy site, there is a xhr-submit event as expected and the site does not reload. I installed the same version of Forms on the Alloy site.
#187591
Jan 29, 2018 10:30
It might be due to lack of @Html.RequiredClientResources("Footer") and @Html.RequiredClientResources("Header") in your page template. Can you check that?
#187592
Jan 29, 2018 10:33
Yes I did miss those lines in my _layout view.
When including those lines I get SSL-protocol errors in the console from webresource.axd so it seems that it tried to load the resources but I'll have to configure ssl for my localhost in order to test.
#187594
Jan 29, 2018 11:20
