Datetime picker form element not working in EPIServer??
Hi Guys,
  i installed date time picker form element from "Install-Package EPiServer.Forms.Samples",but when i drag date time picker its working like textbox and am unable to choose date from it.can any one help me out of this.
Ramkee.G
#187110
Edited, Jan 12, 2018 6:19
Are there any exceptions thrown in the console or the log?
#187201
Jan 15, 2018 22:49
No Ankit,i didn't get any exception in logs but the date picker working like textbox instead of date time picker
Ramkee.G
#187239
Jan 16, 2018 17:30
Moved to Forms fourm.
#187242
Edited, Jan 16, 2018 18:49
Are you using Forms in non-js mode? The Date time picker element require JS to process.
#187257
Jan 17, 2018 3:34
Do you have @Html.RequiredClientResources("Footer") and @Html.RequiredClientResources("Header") rendered in your layout/on the page?
BR,
Marija
#187263
Jan 17, 2018 9:50
Hi Dac Thach Nguyen,
     The JSMode is true in form.cinfig file,still the date picker works like a textbox.
Kartheek
#187472
Jan 24, 2018 6:41
There are 2 things you should check
  • The Forms.config should contain workInNonJSMode="false" (changing need to restart site to make affected).
  • @Html.RequiredClientResources("Footer") and @Html.RequiredClientResources("Header") should be in your layout your page ase Marija said above
If the problem is still there, please give us a support case. We will look inside deeper.
#187482
Jan 24, 2018 11:47
Have Same issue.
I have did all settings as suggested above but not working in console there is 500 erro showing resoource failed load of Episerver Sameple.
Please suggest.
Abhishek
#188018
Feb 08, 2018 14:52
Hi Guys,
   Due to the override the styles and scripts the date picker not working.So before testing the date picker element remove added CSS and Scripts.
Kartheek.
#188019
Feb 08, 2018 15:14
@Kartheek,
Are you talking about the site's layout JS and CSS? which may conflicts with EPi form client resources?
As I am new in EPi form , coudl you please explain it?
Abhishek
#188027
Feb 09, 2018 8:10
Yes Abhishek,Example:-You creat one form(e.g:Registration) with date picker element what you have created.Now drag that registration form in content area of page type(e.g:Home Page).Here don't call any CSS and JS script in view(.CSHTML) of home page.Than run the application and test it properly.The below code is sample of date picker
@model EpiserverSite5.Models.CustomElements.CustomDatePickerBlock2
@using System.Web.Mvc
@using EPiServer.Core
@using EPiServer.Web.Mvc.Html
@using EPiServer.Forms.Core
@using EPiServer.Forms.Core.Models
@using EPiServer.Forms.Helpers.Internal
@using EPiServer.Forms.Samples.Implementation.Elements
@using EPiServer.Forms.Samples.EditView
    Layout = null;
<html>
 <head>
  <meta name="viewport" content="width=device-width" />
   <title>Index</title>
  <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1" />
<link rel="stylesheet" href="//code.jquery.com/ui/1.12.1/themes/base/jquery-ui.css">
<link rel="stylesheet" href="/resources/demos/style.css">
<script src="https://code.jquery.com/jquery-1.12.4.js"></script>
<script src="https://code.jquery.com/ui/1.12.1/jquery-ui.js"></script>
<script>
 $(function () {
  $('.form_textbox').datepicker({
  dateFormat: 'mm/dd/yy',
  changeMonth: true,
  changeYear: true,
  yearRange: "-80:+0",
</script>
</head>
<body>
    <div class="Form__Element Form__CustomElement FormDateTime <%: Model.GetValidationCssClasses() %>" data-epiforms-element-name="<%:              formElement.ElementName %>">
    <div class="form-group row">
       @Html.Label(@Model.Label, new { @class = "col-sm-2 control-label form_label" })
       <div class="col-sm-3" id="calenderspan">
       @Html.TextBox(Convert.ToString(@Model.FormElement.ElementName), null, "", new
           name = @Model.FormElement.ElementName,
           @value = @Model.GetDefaultValue(),
           @Model.AttributesString,
           @placeholder = @Model.PlaceHolder,
           @class = "form-control form_textbox"
    </div>
   </div>
  </div>
</body>
</html>
This Is my Home Page View
@model EpiserverSite5.Models.Pages.Home
Layout = null;
<!DOCTYPE html>
<html>
    <head>
     </head>
  <body>
    <div>
      @Html.PropertyFor(p=>p.Content)
    </div>
  </body>
</html>
#188028
Feb 09, 2018 8:28
@Kartheek,
Thanks for reply!  Tried as suggested, but not working. Same  500 error with plane html. Don't know what I am missing here.
Rgegards,
Abhishek
#188034
Feb 09, 2018 9:53
Can you post your error???
#188040
Feb 09, 2018 10:10
I am having the same issue. It doesn't seem like it is Datepicker specific because with any form after downloading forms.samples I get this in the javascript console:
 GetFormInitScript:7 Uncaught TypeError: Cannot read property 'Forms' of undefined
at initializeOnRenderingFormDescriptor (GetFormInitScript:7)
at GetFormInitScript:32.
Edit: I fixed the issue by adding the @Html.RequiredClientResources("Footer") and @Html.RequiredClientResources("Header") in the layout as mentioned above
#206462
Edited, Aug 21, 2019 18:13
