EpiServer Forms: TextboxElementBlock how do I add attributes like maxlength?
I want to add maxlength to my input textbox (I use epiServer Forms 4.2.1), but I can't do this in epiServer CMS.
There is an option to make this work? There is a clue in the code that it is supported:
<%: html.rawmodel.attributesstring>
#174340
Jan 24, 2017 17:10
One of the way is to override display template for this element and take control of resulting markup yourself.
#174354
Jan 25, 2017 7:55
I understand this is an option, but there is no away to fill this 'AttributesString'? Because when you decompile the source code, you can see that a key value pair is rendered to html properties into the ascx.
I just can't figure out where to fill these values..
#174370
Jan 25, 2017 9:20
Model.AttributesString is constructed based on available validators for particular form field block.
For instance by default for input field, following validators are available:
RequiredValidator
RegularExpressionValidator
EmailValidator
DateDDMMYYYYValidator
DateMMDDYYYYValidator
DateYYYYMMDDValidator
#174377
Jan 25, 2017 10:52
BlockBase.AttributeString calls BlockBase.GetAttributes()
If you want to add new attribute to the output of BlockBase.AttributeString, please modify the GetAttributes()
TextBoxBlock is just a built-in element. If you want to change default behaviour of (built-in) TextBox, I think you should override its template and business to your own need, to create your customizedTextBoxBlock element.
#175894
Mar 06, 2017 8:44
i see email validation on text field doesnt work and we still get spam (in email field as non emails) . How can we enable server side validation for text field ?
#211336
Jan 03, 2020 11:07
Hi, the EmailValidator will validate on both client side and server side as default. You can disable javascript on browser to see if it validate.
#215749
Jan 13, 2020 6:42
