You can hide standard elements from editors in this way
[InitializableModule]
public class HideFormElements : IInitializableModule
Type[] formElementsToHide = new Type[1] { typeof(TextboxElementBlock) };
var contentTypeRepository = ServiceLocator.Current.GetInstance<IContentTypeRepository>();
foreach (var type in formElementsToHide)
var contentType = contentTypeRepository.Load(type);
if (contentType.IsAvailable)
var clone = (ContentType)contentType.CreateWritableClone();
clone.IsAvailable = false;
contentTypeRepository.Save(clone);
In the solution I'm working with we have a need to add an extra property field to many of the form elements. After we extend each element and add the extra property we would like to replace the standard element block (from Forms) with the new block that we've created; so that site editors can only add our customized element to the form.
Is this possible to achieve?
Thanks!
