Following up, the error only seems to occur when I place blocks in folders. I tried a few different folders and they all fail. But if I place the block in the “for this page” folder, it works fine. Is there some sort of security or setup that needs to be changed here?
Are you sending the correct header. Is your content in en or en-us?
Accept-Language
This is the underlying error:
EPiServer.Framework.Cache.ObjectInstanceCacheExtensions : Failed to Read cacheKey = 'EPPageData:320537:en-us'
System.NullReferenceException: Object reference not set to an instance of an object.
at EPiServer.Core.Internal.DefaultContentProvider.GetLanguageId(ILanguageSelector selector)
at EPiServer.Core.Internal.DefaultContentProvider.LoadContent(ContentReference contentLink, ILanguageSelector languageSelector)
at EPiServer.Core.ContentProvider.<>c__DisplayClass127_0.<LoadContentFromCacheOrRepository>b__0()
at EPiServer.Framework.Cache.ObjectInstanceCacheExtensions.ReadThroughWithWait[T](IObjectInstanceCache cache, String cacheKey, Func`1 readValue, Func`2 evictionPolicy)
EPiServer.ContentApi.Cms.Controllers.ContentApiController : Error occurred during Content Api Get Request
at EPiServer.Core.Internal.ContentInstanceCache.ReadThrough(ContentReference contentLink, String selectedLanguage, Func`1 readValue)
at EPiServer.Core.ContentProvider.LoadContentFromCacheOrRepository(ContentReference contentreference, ILanguageSelector selector)
at EPiServer.Core.Internal.ProviderPipelineImplementation.GetItem(ContentProvider provider, ContentReference contentLink, LoaderOptions loaderOptions)
at EPiServer.Core.Internal.DefaultContentLoader.TryGet[T](ContentReference contentLink, LoaderOptions loaderOptions, T& content)
at EPiServer.Core.Internal.DefaultContentLoader.Get[T](ContentReference contentLink, LoaderOptions loaderOptions)
at EPiServer.ContentApi.Core.ContentLoaderService.Get(ContentReference contentReference, String language, Boolean fallbackToMaster)
at EPiServer.ContentApi.Cms.Controllers.ContentApiController.Get(String contentReference, List`1 languages, String expand, String select)
This error only occurs in prod. I can pull the content of the page using: https://<url>/api/episerver/v2.0/content/<id>?expand=*. The content returns for the page, but when I use the block ID to pull that data, it gives me a 502. Any ideas on what's going wrong here?
