I am able to download that package from the link http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0.
So you should try again.
Hi Dung,
I have tried many times, and have only resorted to posting a question here after seeking answers elsewhere on the internet. Since posting this question I have also tried to access another nuget package from within another Episerver project and have encountered a similar problem, so i can surmise that either a) There is genuinely an issue with the Episerver Nuget feed, or b) there is some other network restriction that is not immediately apparent.
Marshall
What do you get when paste the link http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0 into browsers?
I was able to install that version into Episerver COmmerce project. The log file like below.
PM> install-package EPiServer.Social.Common -version 1.0.0
Attempting to gather dependency information for package 'EPiServer.Social.Common.1.0.0' with respect to project 'EPiServer.Reference.Commerce.Site', targeting '.NETFramework,Version=v4.5.2'
Gathering dependency information took 920.38 ms
Attempting to resolve dependencies for package 'EPiServer.Social.Common.1.0.0' with DependencyBehavior 'Lowest'
Resolving dependency information took 0 ms
Resolving actions to install package 'EPiServer.Social.Common.1.0.0'
Resolved actions to install package 'EPiServer.Social.Common.1.0.0'
Retrieving package 'EPiServer.Social.Common 1.0.0' from 'Episerver'.
GET http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0
OK http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0 288ms
Installing EPiServer.Social.Common 1.0.0.
Adding package 'EPiServer.Social.Common.1.0.0' to folder 'C:\Sources\Quicksilver\packages'
Added package 'EPiServer.Social.Common.1.0.0' to folder 'C:\Sources\Quicksilver\packages'
Added package 'EPiServer.Social.Common.1.0.0' to 'packages.config'
Successfully installed 'EPiServer.Social.Common 1.0.0' to EPiServer.Reference.Commerce.Site
Executing nuget actions took 2.85 sec
Time Elapsed: 00:00:03.9043077
PM>
Hi Dung,
I get the yellow screen of death:
[NullReferenceException: Object reference not set to an instance of an object.] System.Object.GetType() +0 EPiServerNuget.Nuget.EPiServerPackageService.DownloadPackage(HttpContextBase context) +297 System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +625 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +270
Regards,
Marshall
Ah, I got that error, but the feed works good now. Please try it one more time.
Hi Dung,
Well the package is there in the browser, but when i try to install from within VS2015 it still fails:
Error downloading 'EPiServer.Social.Common.1.5.1' from 'http://nuget.episerver.com/api/v2/package/episerver.social.common/1.5.1'.
Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
and the same with 1.0.0
Error downloading 'EPiServer.Social.Common.1.0.0' from 'http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0'.
Install failed. Rolling back...
I guess that because of your network connection.
PM> install-package EPiServer.Social.Common -version 1.5.1
Attempting to gather dependency information for package 'EPiServer.Social.Common.1.5.1' with respect to project 'EPiServer.Reference.Commerce.Site', targeting '.NETFramework,Version=v4.5.2'
Gathering dependency information took 993.65 ms
Attempting to resolve dependencies for package 'EPiServer.Social.Common.1.5.1' with DependencyBehavior 'Lowest'
Resolving actions to install package 'EPiServer.Social.Common.1.5.1'
Resolved actions to install package 'EPiServer.Social.Common.1.5.1'
Retrieving package 'EPiServer.Social.Common 1.5.1' from 'Episerver'.
GET http://nuget.episerver.com/api/v2/package/episerver.social.common/1.5.1
Removed package 'EPiServer.Social.Common.1.0.0' from 'packages.config'
Successfully uninstalled 'EPiServer.Social.Common.1.0.0' from EPiServer.Reference.Commerce.Site
OK http://nuget.episerver.com/api/v2/package/episerver.social.common/1.5.1 325ms
Installing EPiServer.Social.Common 1.5.1.
Adding package 'EPiServer.Social.Common.1.5.1' to folder 'C:\Sources\Quicksilver\packages'
Added package 'EPiServer.Social.Common.1.5.1' to folder 'C:\Sources\Quicksilver\packages'
Added package 'EPiServer.Social.Common.1.5.1' to 'packages.config'
Successfully installed 'EPiServer.Social.Common 1.5.1' to EPiServer.Reference.Commerce.Site
Removing package 'EPiServer.Social.Common.1.0.0' from folder 'C:\Sources\Quicksilver\packages'
Removed package 'EPiServer.Social.Common.1.0.0' from folder 'C:\Sources\Quicksilver\packages'
Executing nuget actions took 2.87 sec
Time Elapsed: 00:00:03.8819645
PM>
I have tried to install Social into a project using Nuget, but it fails -
Install-Package : Error downloading 'EPiServer.Social.Common.1.0.0' from 'http://nuget.episerver.com/api/v2/package/episerver.social.common/1.0.0'.
I tried with the latest version as well - same outcome. I am using .Net 4.6.2 and VS 2015. It is quite annoying as i arrived at this point by following the instructions on the Episerver website:
https://world.episerver.com/documentation/developer-guides/social/social_platform-overview/Installing-Episerver-Social/
does anyone know why this is happening?
Regards,
Marshall
